What octane of gas do you use?
What octane of gas do you use for your 4Runner?
  • 87 unleaded
    Votes: 501 67.9%
  • 89 unleaded
    Votes: 88 11.9%
  • 91 unleaded
    Votes: 149 20.2%
  • Total voters
    738
Wilmarbury
I have a 2005 Sport Edition. For the first month, I used 91. But now I use 89. I've never used 87, but I wanted to know what everyone else uses and if they've seen a difference.
Wilmarbury
I pump 93 octane (SUPER)! It was not an option so I did not vote. I notice a difference going from 93 down to 87-89. To me, it seems as if the car did not want to go. But then again, I only pump Chevron cuz I think it makes a world of difference.
I pump only super into my truck. I want to get the most performance out of it and I feel it will help down the road. I just can't can't give my V8 regular but that is just my opinoin.
Read your owners manual on recomended octane, cars are built to run on certain octane levels unless you upgrade intake,exhaust,engine managment etc.
running high octane does not make your stock car/truck faster run better.
I am sure this has been beat to death in another thread.
All Toyotas exept for the new celica/matrix/corolla with the beefed up 1.8L engine just need 87.
I have to confess that every once in a while I throw in the good stuff (91 or 93). I know the 4runner doesn't require it, but I like to spoil my baby every once in a while...
My manual says 87 but for towing or extra performance burn ~91.
I did a test when I first got it. Five consecutive tanks of 87 and five of 91. I did get "slightly" better gas mileage with the 91 but because of the price differential, the increase in MPG did NOT offset the increased price per gallon. I've been burning 87 every since.
Premium Unleaded 91 all the time. :D The extra costs are nominal so... why not! Keeps me happy. Keeps her happy.
mikes4runner said:
Read your owners manual on recomended octane, cars are built to run on certain octane levels .......
Yep, Page 391 (2004)
"Fuel
Fuel Type:
Unleaded Gasoline, Octane Rating 87
(Research Octane Number 91) or higher.
For improved vehicle performance, the
use of premium unleaded gasoline with
an Octane Rating of 91 (Research Oc-
tane Number 96) or higher is recom-
mended."
mikes4runner said:
.....unless you upgrade intake,exhaust,engine managment etc.
What you say would be true for an engine that is purely designed to run 87 octane, but not so if the engine is designed to use 91+ octane and is using an ECU & knock sensor to compensate for lower octane by retarding the timing to prevent detonation.
Typically it is compression ratio, (amount of boost for non N/A), valve timing and ignition advance that establish octane requirements.
jlb
It is my understanding that you should only use what is recommended by the manufacturer. I use 87, because that is what is recommended. I have always heard that unless your engine is built for higher-octane...don't use it. Your motor may actually be more efficient. Higher-octane is generally used for cars with a high-compression or forced-induction.
I started out using 91 but switched to 87 and have been using that for about 5 months now. If there is a difference in performance I didn't feel it so I'm sticking with the 87.
summer/winter blends of gas
you guys know that there are summer and winter blends of fuel right? the summer blend is a bit lighter and causes less polution. but i hear that it offers less gusto. burns a bit quicker. here's a link:
http://www.slate.com/id/2098672/
i use a brand name 91 octane just because i hear that the detergents in them are better. but hey, what do i know? just an everyday consumer.
I use 94 octane from Chevron only.
My truck seems to run a little better with the mid grade stuff. I`ve heard that 89 used to be regular and I really noticed a difference so it`s worth the extra money. I get a discout on gas anyway so it works out to the same cost as regular gas would be without the discount.
When gas was cheap (relatively speaking) I ran 89 and 92 octane. For the past year or so I've gone with 87 and haven't noticed any significant difference in performance. It's not quite as responsive when I have my foot mashed to the floor, but I do that so seldom that the cost difference isn't worth it.
91
I've used 87 once and it felt like it downshifted alot going up hills, and it never did that with 91. plus I think an extra $3 for a tank of 91 wont kill me when a tank of gas is already $55.
91 unleaded all the way. It's not that much more expensive vs 87 in my area. 15 cents maybe. That $3 per 20 gallons. I can live with that. =)
