What products would you like to see developed for the 4runner?
They make those already. I think the company is Westin.
I think you're cornfusing what I'm referring to with one of these:
AKA a Bullbar, which I already have:
Not quite the same.
Closer, but still not what I'm talking about:
https://www.google.com/search?q=pre...xPTbAhUDqlkKHerUB1gQ_AUICygC&biw=1536&bih=807
Imagine [MENTION=152854]JasonRSG[/MENTION]'s T40R bumper, slightly modified with a stinger type hoop that would fit two or three 8" round lights that was a simple bolt on and did not require the complete/partial removal of the oe bumper
Not quite the same.
someone actually made an actual lightbar that mounted through the bumper but i think it was for the pre-facelift models only
An $800 drop-in v8 with gobs of low-end torque that gets 30mpg. :rofl:
Actually, I'd just love to see some options for LoPro bumpers for the 10-13 4Runners. We almost have one from [MENTION=147044]AdventureMotors[/MENTION]!
You can get the universal bumper brackets from Rago and add the outside mount option. Along with a KC hilites Pro6 LED light bar to achieve a similar look. But it does not any bar which is I think more of what they are after vs the lights.
https://www.ragofabrication.com/collections/5th-gen-4runner/products/2014-2017-toyota-4runner-universal-led-hidden-bumper-bracket-stainless-steel
I would like a factory emblem that says this thing is a 4X4.
More long travel front suspension option.
I'd love to have a +1 and/or +2 option that doesn't require all new suspension coilovers. Something like what FROR does for the 3rd gens. They are built for all around use moreso than optimized for desert. Long travel isn't totally necessary. Nor is a longer coilover. Just a bit wider for larger tire fitment. And their design also has quite a bit better ground clearance. It fits OEM coilover length. It absolutely does compromise high speed performance. But that's not my primary goal. This would be a better fit for what I want on my 4runner. It also retains the stock spindle.
Next on my wish list would be a conversion kit to swap the entire front IFS system from a Tundra or LC200 and a rear axle from an LC200. The rear should be easy. The front should be do-able too. The advantage would be a big improvement in strength all around. And a wider track width, with mostly off the shelf parts like axles, bearings, etc. It would of course require 5 x 6.5 pattern 18" or larger wheels. But you should be very durable even with much bigger tires.
Exactly, its more of the specific look I'm after rather than the ability to just mount lights.
I've seen the Rago/KC combo and briefly considered it until I saw the $1400 price tag.
OrangeVirus hand held tuner with multiple tunes....supposed to be in the works. Hopefully as good of results or better than the 3rd gen 2gr Tacomas have reported.
a nice turbo kit that lets the 5gen put down 500whp+ 500tq to the wheels.
Also a nice standalone ecu that lets you plug a laptop via a usb port for fuel/ignition/tuning capabilities like Hondata.
lol
Jhunt
