What psi do YOU air down to?
Bijan
I have 285/75/16 Goodyear Duratracs - normal road psi - 32
Off roading - 20...still too high?
p metric or lt?
i dont think they make that size duratrac in P, only in LT.
anyways i dont know if i am doing it wrong but the people i went with told me to air down to 19-20, i have P rated tires and not LT. not sure how much of a difference that makes. (265/70/17 cooper at3)
I have p metric terra grapplers and I air down to 25. I dont want to cut my sidewalls. if he has LT tires the guys i run with air down to between 8-15 psi
Don't overthink it. 20PSI is a good place to start. Adjust up or down as you feel comfortable/safe and the terrain dictates. If your teeth are in your lap you know you can let some more air out, if you blow a bead you know you went too far down. :D
Makes a huge difference. I wouldn't go below 25 PSI unless you like pinchflats.
I could only really feel a difference in ride quality below 15 psi, anything above seems to kind of defeat the purpose IMO...
there are quite a few variables. tires, vehicle weight, terrain etc..
for my 85 4runner on 35" radials, I drop down to 10 psi. that seems to give me the best traction, and no blown beads.
for my truck on big bias ply tires, I drop to 5psi, and then adjust(down) as the day/terrain calls for it.
the larger the tire, the further down you can, and have to go. for the 285, I think 12-15 would be as low as I would go.
it also depends if you have a dependable means to air back up....
My more recent 36x12.50 and 37x12.50 on 8" rims I've always dropped to about 8-10.
My older 31x10.50 and 32x10.50 on 8" rims I used to drop to 10-12.
In 23 years of four wheeling (the same truck the whole time) I only lost one bead with the 32s and one with the 36s.
I run my 33" LT Nitto Terragrapplers at 46psi road pressure and 18psi off-road. 18 has been pretty good for most everything so far, I haven't experimented with anything lower yet since I've had good results with that pressure; if you're running LT's 18~20psi is a good starting point, if you're running P-rated tires I wouldn't go lower than abouut 22~24psi.
Does anyone use TrailHead tire deflators?
Word on the street is the Staun deflators are where it's at..
I've used them once, borrowing them from a buddy. Dropping all 4 corners simultaneously is a nice time saver.
Last time I went out I just used the inflator attachment with built in gauge from my Viair 400P compressor set and used that to air down. Didn't take MUCH longer than my buddy with the Staun's, and you just have to pay a little more attention to the gauge.
I run Staun's deflators, they work great and after setting them drop down to 18psi pretty damn reliably.
Yup. Love mine. These others are better though, the same design but you can adjust them on the fly and start them manually if your tire pressure is too low to start the deflater automatically. A buddy has a set and they're better than my Trailheads in every way.
Automatic Tire Deflators PRO - 4wheelair.com
Pricier than than the Staun's I bought, but I am digging the indexed threads; that's pretty damn cool.
I have gone all the way down to 5psi with bfg. It was up in the mts in snow.
My normal range is about 15 through 20psi.
Now note I have a bead lock wheel also.
Blue
My rule of thumb with airing down is similar to what others have said. You should be fine going down to 15psi, but I have seen some 33x12.50-15 duratracs get cut sidewalls when in the rocks. They were typically on Jeeps though. If your using a factory rim or a 7-8" wide rim, you should not have to be too concerned about blowing a bead at pressures down to 10psi. I have 295 75 16's on my 1999 T4r, and they seem ok in the rocks at between 10-15 psi. I run a different kind of tire though. I would air down to 20, see how they flex/grip rocks and such, and maybe drop it to 15-18psi after lunch and see how they work. It does take some experimenting, and may change again as the tires age.
I started at 25 on my P rated Duratracs (255/75/17) and ended up dropping down to 20, which seemed to be a good balance of grip and comfort.
