Went through 110 of the pages and have not seen the setup I want so the questions come out.
And what unique setup are you wanting to run? I'm pretty sure whatever you want to run at least one member here has tried it at some point.
And I was also asking opinions between two options so a picture thread would not help.
Picture thread? Part of the sticky is below:
**************************Aftermarket Lift Options**************************
Spacer lifts:
Spacer lifts are designed to work with your factory suspension components. This type of lift is great for those looking to keep the stock XREAS. Spacer lifts provide added clearance for off road, but they provide no other benefits. If you spend a lot of time off road, or even occasional off road that’s at a moderate level, this probably isn’t the best option for you. Spacer lifts are not made to handle added weight, such as front/rear bumpers. Spacer lifts have very little effect on ride quality. All spacer lifts are essentially created equal. About the only difference between them is the material they’re made of, all end up with the ame results.
Lift amounts range from ½” to 3”. With spacer lifts, it’s important to determine you want. Some people use these to simply get rid of the factory rake. This is accomplished by raising the front 1”-1.5” (most common, some have used different amounts). Others choose to lift both the front and rear. It is common for the kits to be sold in unequal sizes. The front is typically 1” higher than the rear, which also helps to get rid of the factory rake. It is important to note that you will gain double the spacer thickness in lift in the front ONLY. For example, a 1” thick spacer will provide 2” lift. A 1.5” rear spacer would net 1.5” lift.
Here are common choices for spacer lifts, listed by manufacturer.
Cornfed
• Front: 1” net lift spacer
• Kits: 2” front & 1” rear net lift, 3” front & 2” rear net lift
Daystar-
• Front: 1” thick Budget Boost spacer, 2.5” net spacer
• Rear: 1.5” thick spacer
• Kit: 2.5” front & 1.5” rear
Toytec
• Front: 1/4” thick spacer, ½” thick spacer, 2” net lift spacer, 2.5” net lift spacer, 3” net lift spacer
• Kit: 3” front & 2” rear net lift
Lift Coils and Shocks:
Lift coils and aftermarket shocks come at a higher price than spacer lifts, but also offer a variety of benefits. These are great for mild to moderate off road use and still have excellent on road characteristics. Unlike spacer lifts, these vary greatly depending on which ones you go with. Lift amounts tend to vary as well, depending on how worn your factory springs are. There’s a little more guess work involved to determine how much lift you will gain. Lift numbers are approximate.
OEM FJ Springs:
• Springs from a 2007+ FJ Cruiser are a direct swap to the 4th Gen 4runner.
• Shocks from a 2007-2009 FJ are a direct swap. Shocks from a 2010+ require some minor modification to fit. Details on the modifications can be found in this thread.
• These provide on average ½”-1” lift on the front, ¼”- ½” lift on the rear, depending on if you have a v6 or v8 engine and 2wd or 4wd.
• Most people buy them used from FJ owners who’ve upgraded
• More information can be found on the following pages
http://www.toyota-4runner.org/suspen...o-4th-gen.html
http://www.toyota-4runner.org/suspen...e-fj-swap.html
Bilstein 5100 Shocks
• Unlike most shocks, the Bilstein 5100 front shocks are adjustable for various amounts of lift.
• Lift settings are 0”, .85”, 1.75”, and 2.5”
• These offer great ride quality and are a good choice for a stock replacement.
• It is very common to pair these with FJ, OME, and Toytec Coils for added lift/performance
OME (Old Man EMU, not to be confused with stock, OEM)
• OME offers different coil options for v6/v8 4runners and also for those at stock or with added weight.
• Provide lift by using more wraps of coils and higher spring rate
- Higher spring rate = stiffer ride
• Front coils-should provide 2.5”-3” lift for listed application
- 883-Good for leveling the front with stock rear-approx 1.5" lift
- 884-For use on stock weight v6
- 885-For use on stock weigh v8, or v6 with added weight
- 886-For use on v8 with added weight
- Front coils often combined with ¼” thick spacer for a full 3” lift
• Rear coils
- 895e-stock weight, 1” lift
- 895-stock weight, 2” lift, over 40% stiffer than stock
- 896-weight added, 2” lift
Toytec:
• Superflex rear coils
- Great option for stock weight , 2” lift, 10% stiffer than stock
Coilovers
These are some of the best suspension systems available. Coilovers refer to the front shocks only. Most are sold in kits with rear shocks/coils that are matched to the fronts. These are best suited for more hardcore off-road use, but they are also excellent on road. The front coilovers are adjustable for lift, typically up to 3”-3.5” lift. This is a huge benefit of coilovers, you can adjust for added weight. In addition, unlike ordinary shocks, most can be rebuilt in case of failure, and also revalved to dial in the ride.
Icon
• Offer a variety of kits to suit your needs
Overland Warehouse
• Kits are designed specifically for the 4runner, unlike other kits which are universal to this platform
• Offer both a 2.0 kit for stock weight vehicles and a 2.5 kit for those with added weight.
• Extended travel kits include an extension bracket for the rear brake lines, info on this in a moment.
Toytec
• Their coilovers are more of a cross between standard shocks and coilovers
• They use Bilstein 5100’s and an added coilover conversion kit.
• Cheaper than other coilover options
• More difficult to adjust once on the vehicle
• Shocks are not rebuildable/revalvable
