What to look for when purchasing an 03 2WD 4runner?
nissanh
Senior Member
Located an one owner SR5 2WD 2003 4runner with 170K miles and clear title.
Seller agreed to sell it for $3600.
Only cosmetic defect is faded paint on the hood, rest is in great condition.
My only concern is the 2WD system. I have a 4x4 97 4runner.
Apart from 4x4 capabilities any other disadvantages in the a 2WD?
I own the same rig your looking at...what's your concern with 2wd system and why would consider 2wd being disadvantage. you may wanna rethink that.
advantages
Thanks!
Perhaps, you can help me to find the followings:
Gas mileage, highway and city?
handling in dry and wet roads compared to 4x4 (not AWD)
Acceleration?
Body roll?
I have never owned an SUV with 2WD so that is why I am bit concerned.
nissanh
Thanks!
Acceleration?
Body roll?
nissanh
I average about 21-22mpg according to the computer so figure 19-20 average with an even mix of city/highway. Handling, acceleration and body roll I wouldn't think would be any more noticeable on a 2wd vs 4wd. If anything it would be better as there is slightly less weight up front. I don't go off roading other than gravel fire roads so I couldn't give you any info there. That seems like a pretty good deal though if there's no issues with it.
Yes, the truck is in good condition. Even seller agreed for me to do a compression test or any test I like. I recently read here in T4R that the compression should be 190 psi, so I'll check on that.
I am getting more and more excited to own this truck now.
Saw you have a locker, I suppose this is a rear locker and is this is factory? if not, how did you install this?
thanks
I've had an 03 SR5 2WD with the 4.7 V8 for about 18 months.
Listen carefully for rear end noise. The diff and axle bearings can get expensive if you're not equipped to do that kind of work yourself.
Mine had the typical console lighting issues and the heat/cool mix door servo motor on mine has failed. A ~$140 part that's tough to get to. Fortunately I can live without heat here on the Gulf Coast. My latest expense is a failed brake booster pump. RIDICULOUSLY expensive to replace.
Other than the cost of repairs I like the vehicle. Comfortable ride, good power and fairly quiet inside for a SUV. Mileage is typical for a V8, 15-17 around town. No road trips yet to check hwy mileage.
[MENTION=85046]nissanh[/MENTION] and [MENTION=93193]morphious[/MENTION]
I average 15-17 mpg's but I run heavy E rated 33" tires with extra weight of rear bumper and roof rack with lights which doesn't help, but also means I can careless about my mpg's.
Handling and acceleration....mmmm wanna race? Then you can tell me. Remember there's only 4 gears so in 4th I have full pedal and throttle response at all times there's no waiting to hit 5th or already being in a overdrive 5th gear. I smoke cars and trucks all day long.
Body roll...mmmm what's that? I wouldn't know since I also have no sway bars....lol and still I don't understand these words you speak of "body roll".
And for myself, it's my fiances DD and I wheel the dog s*#! Out of my rig and she handles every bit of it with a smile. But gets just as much pampered when she gets home, spoiled rotten. She don't let me down then I don't let her down.
Also lighter and less mechanical suspension parts to brake or to go wrong, hence why they are used to haul ass across deserts "pre runners" 2wd rigs. Also can lift them higher much easier with less complications and less money.
Yes I have locker, non oem and non factory. It is a Spartan Locker which has adapted and taken to the 4th gen like it should have been there from factory to say the least, I luv it.p and would change it for nothing. And for $234 bucks brand new and 6.5 hrs of my time by myself in the garage I have a very capable all terrain vehicle. Disadvantage? There is one Achilles heal and that's stopping in soft soft sand, just need to put a tire on some rock,a bush or hard pack. But in the same regards I have wheeled all over Ocotillo wells, devils slide, pumpkin patch etc etc and not get stuck at all.
Also I have 275k with not one major mechanical issue what so ever just regular o'l maintenance and parts replacement that I choose to change or I happen to brake. All of that 275k has been done in my garage no mechanics no stealership.
It's a DD and our off road rig ...so this word "disadvantage" you speak of I do not understand.
I don't want anyone to waste there money and buy a car with it having a disadvantage to them. So how about I go and buy it and let you know if I find one.
Hope this helps
Miah
Hope this helps
Miah
Very well said sir. The only "disadvantage" I currently have is no locker yet. LOL. In almost 13yrs of ownership, I have had no issues with my Runner nor have I ever said "Damm, wish it was a 4x4".
Hope this helps
Miah
Damn I had no idea you had 275k on your rig. Its amazing how durable these things are.
