what v8?????
heyojaybo
hi all, im looking at putting a v8 in my runner but am unsure which engine to go with.
im no million air and looking for an easy conversion.
any thoughts on what i should go with?
Going to need a LOT more information. What gen. 4runner? Auto or 5spd? Budget?
Engine swaps in modern vehicle is no easy/cheap task.
its a 1986 2.4l diesel 5sp
it looks good but it is gutless! and need more power to turn the 37"tyres
hilux.jpg~original
A 5.9L Cummins would be SOOO heavy in a truck that size. You would need a lot of reinforcement in the front. Way too much work for it to be worth it.
Are you doing this swap yourself or having someone do it? Do you have a budget?
If your looking for V8 power I would recommend a GM LS series engine. Plenty of aftermarket support. GM even sells one that is called the "E-Rod". Its a complete engine, harness, even catalytic converters to allow almost any vehicle stay emissions compliant. If your looking to stay all toyota then you have a few choices, in my opinion, but the swap would be harder due to lack of aftermarket support or not as much.
Not what you were thinking, but have you re-geared the diff?
depends on how hard its going to be......
budget around 4g
A friend of mine put a Chevy 4.3L Vortec V6 in has '91 Toyota pickup... solid axle swap, running 35's, twin-stick dual t-case. That 4.3L moves that truck pretty well! I forget which tranny he has... maybe a 700R4. There seems to be a decent aftermarket for that engine, too.
LSx swaps are also popular, but finding a decent used one can get pricey. I've seen guys pick up L33's (the iron block, truck version of the LS) pretty cheap and build them with LS parts.
Good luck!
~Doozi
There is a 4 cyl version of the 5.9. I think it is a 3.9 liter. It was mostly used in small equipment. It has the same bore, stroke, and bell housing. It was a modular type engine.
