What would you use $50 on?
From your screenname pic, it looks like your '03 has the body cladding like mine does. I'd buy 7 (depending on the price you find) bottles of Mother's Back to Black. Wipe it on every 2-3 months or so after washing and you'll be happy with the results.
Not so anal about the cladding as some are here. I have found that magic eraser works pretty well on the cladding and brings out the dark grey. I do however want to eventually remove all the cladding and replace all the clips/ tabs along with new adhesive. Just another item on the list.
but some toyota brand coolant...stuff is expensive but you need it
I've heard (and used) Zerex Asian Formula coolant works, too. I piled my gallon up at the local Napa. It's pink and states on the jug that it is ok for toyotas. It's probably cheaper than the toyota brand, too.
Anyway, I'd probably spend the $50 on gas. It should fill me up these days with gas around $2.27 or so. I do need gear oil though for front, rear, and transfer, so that'll add up in a hurry. Some new spark plugs, I guess. What I should do is save up for another timing belt.
The list is endless.
