Whats going on with my HVAC?
iBison
Every time I turn my runner on the recirc is turned on. I turn it off, next time I start the truck it's back on. I turn it off, turn the truck off, then turn it to on without starting it, recirc is back on. It's not just the light, st switches from outside air to recirc.
Do I not know how to operate the HVAC or is something up with it?
Its because you have the air set to the lowest temp. Turn it up a degree.
I had air and auto off. I had to set it at 73 before it wouldn't do this, 80 outside. Very annoying. I might have to add a switch to disable the switch.
What were the other settings? Was it on floor, defrost, floor/defrost? Think those usually make it happen as well. There IS a way to keep it from doing thaT
I tried floor/defrost, face, face/feet. With auto and AC off. I could see having that "feature" if you have AC on or maybe auto.
as someone else may have referred to, maybe its this reguarding ac function, i imagine the heating works similarly so thats why the computer defaults to recirc.. - The fastest way to cool the air inside the car is to turn on recirculating mode, so that's what the computer does. (That way, you're cooling air you've already attempted to cool , rather than pulling in fresh - but probably hot - air.) Once the inside cools to the desired temperature, and you didn't mess with the recirc button, then the computer will go back to outside fresh air. im guessing a winter example might be if you ever heated the inside then say its warm but stuffy & let some fresh air in, park, turn vec. off, come back in a hour or so forgetting that you left in on fresh air, start it up, the computer resets it to recirc. so that you are not blasted with cold outside air. i believe nowadays these newer systems want to do what they believe is best, not necessarily what you want.
That's honestly something I have never noticed until reading this thread. I always have the vehicle set to recirculate anyways because I only use one setting on my truck year round which is, as my friends call it "Polar Bear Setting." :rolleyes:
I was playing with all the settings and other than defrost I can't get the recirculated to not come on with key cycling. I'm not exactly sure why it does this, the owner's manual says nothing of this feature. But it seems to be absolutely normal, So you might have to just get used to it. Normally if I want fresh air I just roll the window down...
