Anyone been running them for years? Any issues beyond squeak? Your alignments hold true?
2001 here, 182k still on stock suspension. Getting '99 tall springs and Bilstein 4600's installed and definitely doing UCA and LCA bushings. I picked up some Japanese made traditional LCA bushings (sold as MOOG brand), they were cheap, so not opposed to not using them. Curious about the Energy Suspension poly kit with both upper and lowers.
Also doing OEM upper and lower ball joints as well as OEM outer tie rods.
How important are the rear upper trailing arms? The short ones that link to the top of the axle. Bushings have a little play when pry bar'd in a direction perpendicular to the axis of the fastening bolt. Lowers seem ok.
Anything else to consider while in these areas?
