Wheel help
Gstick
Member
Someone PLEASE set me straight on my OEM 17" x 7" 6 spoke alloy wheels. (off of a 2010 SR5 4x4, 4R) I know that the bolt circle is 6 x 139.7 mm or 6 x 5.5". (same thing)
And the backspacing is 4.5"
Now I have read (somewhere) that the offset is 0, but Ultra Wheels (in California) claims that the OEM wheel is a +12 offset. The 17" x 8" wheel that I want has a +5 offset with 4.5" backspacing. I was told that this wheel won't fit. :redbrick:
Also, is the hub diameter the same thing as center bore ?
If these are the same, then I believe my OEM wheel is 108.__ ?
Thanks in advance!
Thanks in advance!
SR5 rims are 17x7 with a 6 x 5.5 bolt pattern and a 4.5 inch backspace.He is correct in that the stock SR5 rim is +12 offset and the Toyota hub diameter is a 106mm. It's a 0 offset if it's a 17x8 rim and 4.5 backspace.
108mm bore on the aftermarket wheels work because the cap usually takes up the other 2mm. At least on my AR Mojave's they do.
Here is a chart to help you. https://www.rsracing.com/tech-wheel.html
