wheel locks
am0767
hello everybody!!
i have a question about wheel locks and lug nuts..
i plan on swapping out the stock wheels on my 2020 SR5P for the 17 inch TRD black matt wheels and i wanted to know .. can i use the lug nuts and wheel locks from the stock wheels on the TRD wheels?
thanks!!
albert m
I am 99% sure that the answer is yes. My '19 TRD ORP came with the matte black TRD wheels and wheel locks. The wheel locks are the same ones that I had on my FJ Cruiser with OEM alloy wheels and the lug nuts appear to be the same as well.
for sure a YES!!
i used the lug nuts, wheel locks and TPMS sensors on them. had the dealer swap them. so you know for sure they work.
thanks!!
hello everybody!!
thanks!!
albert m
Yes. I did the same thing. Like the previous user said, you can swap over the TPMS sensors as well.
Thanks for starting this thread. I'm planning to swap the stock wheels for TRD's as well. I had the same questions about the lugs and swapping the TPMS's.
I wanted to replace the chrome lug nuts on my 2015 TRD Pro I just got and this thread was useful. Wanted to add some more current info based on what I went through.
First, the lug nuts on 2015 models came with longer 1.75" long studs. Current ones are 1.5". I ordered 1.5" lug nuts and they fit and look good.
I ordered black Toyota OEM lug nuts, part #PT076-60200-02, on Amazon for $20 per six pack.
I also got a four pack of wheel locks that match up well with the Toyota lug nuts. Gorilla Automotive 71631NBC Acorn Black Chrome Wheel Locks (12mm x 1.50 Thread Size) for about $24.
Tools you'll need . . .
13/16" deep socket 1/2" drive
5" socket extender 1/2" drive
1/2" torque wrench set to 85 ft/lbs based on what read. I then set it to 90 ft/lbs in the end in case my torque wrench was a little off.
Those wheel locks are acorns so they aren't going to work w/ the wheels, they need to be mag lug.
