Wheel Lugs
dirtbike250x
So when I installed my procomp wheels the front studs needed to be extended, so I went out and purchased new studs and lugs. This summer I will be using the 4runner for an almost daily commute, and would like to save the duratracs from the unnecessary wear. I have the stock wheels and 31s with good life left in them still, but with the new studs up front the stock lugs are no longer large enough. The new studs are a larger diameter and also a different desgin (the standard acorn shape compared to the stock ones with the sleeve on the thread side of the lug). Im not totally sure of the my current diameter of the lugs, was just wondering if there is such a thing as the stock style lug with a larger hole. Thanks for any advice. :hatsoff:
Most Autopart stores carry out nuts. They come in a variety of sizes, possibly the are 14x1.50 meaning metric 14 with a pitch thread of 1.5. If you take one of the new acorns in and then find a stud (or go to ace and find the bolt that fits) you then just need the corresponding new lugs with sleeves. (Hopefully)
