I recently purchased a set of brand new alloy FJ Cruiser wheels on ebay for a very good price that were a dealership swap. In the process of purchasing, I did not investigate closely whether or not these wheels had the same offset as stock 4Runner wheels and went by claims on other FJ Wheel ebay ads that said they are compatiable with the 03-07 4Runner. The seller of my particular wheels did not make this claim but other ads running at the same time did. After I have purchased them, I noticed that the stock 4Runner wheel has a 30 mm offset and the FJ wheels have a 15mm offset. This equates to providing 15 mm (0.59") of more clearance between the wheel and the strut assembly but it also equates to the wheel centerline being off by 15 mm as well.
My question: Is this difference in offset problematic in that it will/may cause harm to the wheel bearings due to the difference in wheel centerline?
The extra clearance is fine and not sure of Toyota did this simply to provide better clearance for the 265/70/17 tires that are available on the FJ. I was going on the assumption that the axle assemblies are the same or at least similar so thought offset would be the same too and was surprised to find out that there is a difference in offset between the two vehicles. I bought these wheels to install a set of Cooper STT 265/70/17 tires strictly for use on offroading ventures and do not plan to run on these wheels/tires for daily driving. I was hoping that a 15mm offset difference won't be a big deal and makes me wonder how this could be any different than wheel spacers as far as potential harm to wheel bearings since they too shift wheel centerline.
Appreciate advice of someone very very knowledgeable in this realm or can direct me to someone who is. Thanks in advance.
