Wheel Question - SR5 vrs TRD Pro Wheels
Roverguy1
Excuse the noob question but, currently have a 2014 SR5 with snowflake wheels. I am considering getting a set of TRD Pro Wheels. Are they both the same size 17x7? Is the offset the same or do they stick out a bit further? Do the same lug nuts work? My new tires are on route and I'm considering the wheel swap at the same time. Finally, anyone with a black SR5 running the gray TRD wheels? If so, any photos? I'm kind of leaning that way for some contrast. Thanks all!
Answer to question: yes
I can confirm the TRD Pro wheels stick out a little further. I went from SR5 to TRD Pro wheels.
Not black but some food for thought.
I got these during the TRD 40% off anniversary sale. They look much better than the SR5 wheels!
Did the same thing.
Yeah both are 17x7 but different offset. TRD pro rims are 4 lbs lighter which help offset my heavy new tires:doh::madgrin:.
Did the same thing.
They are not the same width. If I remember correctly, the SR5 wheels are stamped 17x7.5
Here is a photo of the boxes when I picked up my TRD PRo wheels from a Toyota Dealership. You can see '17x7' clearly on top of the boxes.
idk man looks like you used a sharpie lol
my 2018 SR5 are 7" wide, I measured them.
the factory SR5 and the TRD PRO wheels are both 17x7" dimension whereas the SR5 wheel have positive 15mm offset and TRD PRO have negative 4 offset. The Trail Edition/TRD Offroad is 17x7.5" dimension
TRD PRO and SR5 wheel have same dimension. Both 17x7" however they have slight different offset. SR5 is positive 15mm offset and TRD PRO is negative 4mm offset I believe.
me too. And I was able to sold my old SR5 wheel. The TRD PRO have more negative offset so it sticks out towards the street more than the SR5 wheel.
SR5 wheel is positive 15mm offset
