The noise came back. I believe I will have to change the serpentine belt. But I'm a little confused. From the research I've done, the Serpentine belt is whats in front of the engine (what I sprayed), right behind the bigass fan at the very front of the hood. Correct? That is different from the timing chain, which is in my v6, vs. the v8 which has a timing belt. Am I still tracking? What is the difference between belt and chain. Belt should be changed at 90k, but when should the chain be changed.
Also, do I need to change the water pump too, if I change the serpentine belt and tensioner? And is this a stealership type deal... or is this a DIY type thing?
