Methodical said:One important thing to always remember in a panic situation is to sit on the brakes. Slam on the brakes BEFORE you turn and no car with ABS will lose control. You won't even trigger VSC.
Try it in a car in a parking lot. If you turn then brake, you will lose it. If you brake then turn, you never will.
Falls said:The higher it is the easier it would be to roll. Hard to tell with speed. VSC wont have anything to do with not rolling over , it might help to keep you on track so that the chances are slimmer , but it won't prevent it.
Falls said:VSC wont have anything to do with not rolling over , it might help to keep you on track so that the chances are slimmer , but it won't prevent it.
Even Steven said:
I'm not saying that it is impossible to roll a vehicle with VSC, I'm just saying that it is much easier to roll a vehicle that doesn't have VSC than one with VSC.
Falls said:Try it see if it helps .
Even Steven said:Yeah, okay.... like I'm gonna risk my safety and my 4Runner by trying to roll it just to prove you wrong.
Falls, sometimes you remind me of an old grandpa who just hates technology and refuses to believe that it can make anything better. If you want to believe that VSC doesn't help mitigate the risk of a rollover, then I doubt anything will change your mind. Unless of course you find yourself in a hairy situation with your 4Runner where the VSC helps save your ass. But even then, you'd probably just think it was your superior driving skills that saved you....
BTW, the front driveshaft of my 4wd 4Runner still doesn't turn when I'm not in 4wd HI or 4wd LOW![]()
4rnr4me said:I have a 2.5: lift, and feel almost no difference at all, but that MAY be because I also have wheel spacers...that would make it more stable right?
