Where do you buy all the parts from? My buddies shop said parts from toyota was like $500 plus for just parts alone.
Then again i do have both sides leaking.
Thanks!
Also around average how much did you guys pay for parts and bearing all that new stuff to repress on the axel.
Thanks for the picture!
Okay so I changed the circled red inner oil seal. Cleaned up the brakes and everything and now couple weeks later I peak under and it's leaking again.
I checked it even more seems like what's picture on the bottom half, everything is pushed more outward of the vehicle and so it's not really pressing against the oil seal at all.
A couple of things to consider (unless the bearing assembly is in fact pressed in the wrong location):
1: Make sure you haven't overfilled the diff. The vehicle should be on level ground when you fill it. If you put too much fluid in, it will push out the seal.
2: Did you use Toyota's OEM seal? I would for sure use the Toyota seal as it is designed differently than Napa/Autozone. Ask me how I know...
3: Be sure you drive the seal in cleanly. If you're using a screwdriver or any single point of contact, there is a chance you're damaging the seal. Use a seal driver or this.
If the problem is in fact that your wheel bearing isn't pushed in all the way, I would be surprised because the problems you're having would have manifested themselves long ago I would think. But who knows...
Also what's considered to much diff oil? I put it in on flat ground up till the fill hole.
Thanks for the help guys I really appreciate it.
Okay so far I bought the inner oil seal circled in red you have above and then I took off the axel then pressed in the new oil seal pretty straight. I used a seal driver. What I'm guessing now is your saying that there is a way where it can be pressed in too much?
Ok, that paints the picture much better. What RJAudi and econhonda said are good ideas (do the diff breather extension mod while you're down there, even if you don't do river crossings, relocating it to the gas cap will help alot to keep it clean). I think you can overload a bit on oil and be fine, but if you breather is clogged and you have too much oil, then you might get in trouble.
As far as the install, I am certainly no expert but i have done it. 1st thing, check out BigFishAllDay's walkthrough. Post #6 talks about the proper depth. I recommend getting a proper straightedge and steel rule to check the depth (make sure the rule goes all the way to the end, so not a normal ruler). You can get a cheap 6" rule from harbor fright for pretty cheap (very worth it).
During install, I had trouble getting the seal started, it always wanted to go in a bit crooked. If it didn't go in all the way around with the first hit, it deformed slightly and I couldn't get the other side in; I would pull it out and try again being careful not to bend or nick it. Might help to take small taps an be patient trying to get it in, though in the end I think I whacked it pretty good to get it started. From there I repeatedly measured the depth all the way around (top/bottom/left/right should be sufficient) and tapped it in straight and slow until my final depth was met. I have had no leaks since then (I did it this spring, put on probably 10k miles on since then).
I bent 1 seal up trying it for the first time. Let us know how attempt 2 goes.
I had to do one recently and got my first seal butchered. Got a proper seal driver and the 2nd one worked ok so far. The tougher part was to remove the old seal (without a seal puller) without causing too much damage.
While the axle is out, it's important to regrease the bearing. If you're careful enough, you can pry open the plastic seal ring (from the inner edge). I repacked it with some Valvoline Syn power grease I have, and so far so good. Most of the original grease was already washed out, and I had to do quite a bit cleaning before putting new grease in.
is there a certain grease specific to buy? also how do i regrease it, or what im asking is you have tips? haha im not 100% sure how ill regrease it.
Change your diff breather I have heard that can cause the seals to fail and is cheap.
