Where to buy the cargo cover?
WTB cover for 1997
Hey guys,
I want to buy one (pref beige but any color is fine). I have a 1997 with a square bracket. I have in Victoria Canada and will pay the shipping.
My email is [email protected] if anyone still has one to sell!
Kevin
1996-2000 have squared cargo cover ends.
2001-2002 have rounded ones.
I swapped my cargo panels in from a wrecked 4Runner, as well as brackets, then traded a gray cargo cover with driffter33 for his oak one.
It's always in use when it's possible.
I'm new to this. Does that mean, if my panels don't have mounts on them, I have to find panels with mounts to swap them out if I want to use a cover? I.e., I can't install mounts/brackets into my current panel?
Thanks in advance.
Do you still have this cargo cover available. I need one?
Hey, do you still have the cargo cover available. Really could use this.
I have a tan one out of my 00. some one can have.
I never use them and probably never will.
famous last words when its dont is I will want one. lol
I am not totally sure of its condition cause when I bought the rig i took it out and put it in the corner.
PM me. I am in Montana
Thanks in advance.
Unfortunately no, you have to swap in the panels since the mounts are metal and molded into the panel plastic, etc. I was gonna cut them until I saw how it works in there. Junkyard time!
On a positive note, if you have a pre99, you can swap to the panel with the larger cargo compartment.
Looking 2000 Toyota 4Runner Cargo Cover
I am looking for a Gray or Tan Cargo Cover for my 2000 4Runner. I don't have any mounting brackets in the 4Runner where can i get those too?
I have a GREY one from a 2000
Im looking for a TAN one that will fit my 2000
Possibly sell my GREY one.... decent/good shape
Local trade (seattle/washington) would be perfect
shoot me a PM or email [email protected]
Where can I get the end caps?
Does anyone know where I can get the end caps to the cover? One of mine broke and I don't need to replace the whole cover (it's still in good shape).
actually, the brackets can be installed on those panels that didn't originally come with the brackets.
If you remove the panels and look at the back, the locations where you need to make the cut-outs are clearly marked on the panels. All you need is a sharp knife to make the cut-outs. Then you can reinstall the panel and then screw in the brackets.
<img id="ums_img_tooltip" class="UMSRatingIcon">
How did you mount the brackets closest to the lift gate? Those usually screw into metal brackets that are part of the other panel. For the brackets behind the seats, did you source the small square inserts for the screws to drive into? Or did you have to rig it up somehow?
i sourced the brackets with screws/yellow plastic inserts from Toyota. After making the cut-outs in the panels and reinstalling them, you can see the holes where to place the yellow plastic inserts. The yellow plastic inserts are where you're gonna install the screws. These procedure applies to all 4 brackets.
Philthyphilthy
