Where's The Draft Coming From!
12guns
I'm used to an extended cab Tacoma...not sure if it's just the larger space in the 4runner or if there's a bad door seal somewhere...It seems air tight when I roll up the windows I can feel the change in pressure...Anyone else feel a draft while driving? Or am I just crazy?? Seems like it's up front by the window/door. I guess it may just be the cold weather, but sometimes I can swear it feels a bit drafty! Anyone? Anyone??
When its cold I can feel the cold coming off the windows and down from the moonroof if I forget to close the shade.
It's winter... ;):
Are you in fresh air or recirculating mode?
It's winter... ;):
:iagree: It's that much colder if the moonroof shade is left opened.
Even if your fan is in the off position, air will flow through the vents when you drive (unless you're in "Recirculation"). Whenever the "draft" bothers me, I switch the fan to the "windshield" position, then I don't feel the draft anymore.
