Which awning brackets for sso rack w rtt?
I have a full length southern style roof rack and cvt roof top tent. Im wanting to mount an arb awning but theres so many brackets available i am confused. Any recommendation?
Some awnings will come with the bracket. If not, this might work.. Although if you get 3 it would be close to $100.
Here is one LFD Off-road sells. 2 for $60. Only sold as a pair.
If you want to be able to take it off easily for storage in your garage when you are not using it, you can try this.
I don't have a RTT but I mounted by ARB 2000 using these brackets from 4WheelParts. The three-hole side mounts to the rack while the 2-hole side mounts to the awning. Let me know if you need pics or dimensions.
They're cheap - I used 3, but 2 should be fine (one near each end). Very study - I regularly use the awning as a hand hold when accessing the roof rack from sliders.
MMJR_T4R
