Which front lift??
ColoMike01
I have some 265/70/17 Grabber ATs coming in but now Im not sure what lift. I just want to level it out in the front, but don't mind it slightly taller up front. I am wondering who has just the Daystar 2.5 up front and that's it??? I have gone through the lift and tire thread but haven't really seen any pics with just the front . So just curious who on here is just running the Daystar 2.5 or any other brands that are 2.5 or maybe even 3in. Also, I don't do any crazy off roading.... just some mild trails and some hunting and fishing!!!
Thanks, Mike...
It looks like Daystar, Cornfed, and Toytec offer spacer lifts. You could just take the 1 inch spacer and use it up front to level it out. I think it would look silly if the front was higher than the back, especially if you plan to load it down with gear.
I think there at least a few people running just spacers here on the forum. The off road people usually just go the suspension swap route, though. If you don't plan to wheel it hard, you'll probably be just fine with the spacers.
Daystar Budget Boost 1'' - $39
Lifts about 2 inches total up front, looks clean with the front about level if not a touch higher than the rear
I just did the day star lift for $39 bucks. Plus also replace front struts. Left had 2 1/2" clearance and right had 3 1/2". After all said and done both sides have about 4 3/4". I've noticed that getting in or out is a little different now. All I can say is it was good for my pocket!
utkrstam
