Which fuse is for the back-up lights? (lights not working)
nalbertasr5
My reverse back-up lights are not working. Not sure if it is the fuse or the switch on the manual transmission. Before I check the switch, does anyone know which fuse to check? On the cover of the fuse box in the engine bay, it just refers to a Tail 10A fuse but doesn't mention anything about reverse lights. Is that the fuse? All the other lights are working so I am skeptical about it actually being the fuse, just want to rule it out.
Back up lights are powered from the GAUGE fuse.
That fuse also power such things as:
ABS
Air Conditioning (Manual A/C)
Automatic Air Conditioning
Back−Up Light
Charging
Combination Meter
Cruise Control (3RZ−FE)
Cruise Control (5VZ−FE)
Electronically Controlled Transmission and A/T Indicator (3RZ−FE)
Electronically Controlled Transmission and A/T Indicator (5VZ−FE)
Engine Control (3RZ−FE)
Engine Control (5VZ−FE)
Front Wiper and Washer
Headlight (w/ Daytime Running Light)
Key Reminder and Seat Belt Warning
Light Auto Turn Off
Multiplex Communication System
Rear Differential Lock
Rear Heater
Rear Window Defogger and Mirror Heater
Starting (3RZ−FE)
Starting and Ignition (5VZ−FE)
4WD (w/ 2−4 Select SW)
4WD (w/o 2−4 Select SW)
Sounds like it is more likely the switch on the trans that went bad...
-Charlie
ABS
Back−Up Light
Charging
Combination Meter
Light Auto Turn Off
Rear Heater
Starting (3RZ−FE)
-Charlie
Thanks! Also, that Camry you have sounds amazing!
