Which harness interface?
Cubslover
Installing a new JVC HU in my 03 with the JBL/RDS and will need either of these harness interfaces. Anyone biased to one or the other? Is one more work than the other?
Metra TYTO-01 or PAC TATO?
PAC
Metra/axxcess
I just installed an aftermarket Kenwood this past weekend on the same system. I used the PAC-TATO one and all went smoothly. I even bought their other adapter (PAC-SWI I think)..which lets you retain the use of the steering wheel audio controls. They did a good job of showing you how to connect both units together (which I'd expect since they made both). It was a bit more involved having both adapters to hook up in tandem but still pretty straight forward. So, if you're only hooking up the TATO, it'll be a piece of cake.
I'm not sure about the Metra...but the TATO has dip switches on the side (where you see the red area in the pic) that let you turn up the gain if needed to +7db. I installed mine first with it at 0db...but definitely needed to switch it to +7db for the volume to work better with the Kenwood HU.
Metra has an adjustment as well. I have installed both, the instructions with the Metra kit were much more clear to me and therefore made things much easier (also installed this one second so I had an idea of what was needed, so maybe that's it?). Don't think you can go wrong either way.
