which lubricant for powered antenna mast?
which lubricant is best for the powered antenna mast?
  • Total voters
    13
hrt4me
The powered antenna on my '96 SR5 squeals and whines when it retracts, so what is the best lubricant to use on the mast?
powdered graphite
dry film lubricant
oil
grease
When I replaced my power mast antenna, I took the motor apart to get the bits of broken plastic cable out of the motor. It was lubed from the factory with white lithium grease, so that's what I used on the new cable.
If you are talking about the metal sections of the extended mast that can get dirty, I just spray some WD-40 on a rag, and wipe the dirt off the mast.
lithium grease does tend to collect and hold dirt. graphite has always been best for this type of application. It is dry, applies easily, and doesn't leave a film to collect dirt.
I actually use Gun Lube, CLP to be exact. It cleaned the gunk off the antenna, and took away the squeak. It's been 6-8 months since I lubed it and not a peep out of the antenna.
I use nothing.
Just clean & dry. The nothing sticks to it then.
Dirt will stick to any oily or greasy mast.
I'm on my second mast in 15 years.
Just to reiterate, since there seems to be some confusion; the white lithium grease is down in the motor assembly, where the plastic toothed cable which extends and retracts the antenna coils up upon retraction, and uncoils upon extension.
You wouldn't want to smear grease on the exposed (extended) metal mast sections. That would make a mess.
For me, just some WD-40 on a rag to occasionally wipe off any accumulated dirt, keeps it working smoothly.
My first mast from the factory lasted 12 years, the second OEM mast which I installed myself, is still smooth as can be, and should last at least as long as the original.
I dislike having an antenna mast sticking up constantly, or I might have done the often mentioned Tacoma whip mod.
I do exactly this, too. 12 years on first mast, and it broke because the nylon cable was completely brittle. No lube approach would have helped with that.
If it's the final 30%, quickly turn the radio volume up loud enough to drown out the squeaks.
No grease needed, just good timing.
