Which suspension lift kit (2.5-3")
Which lift kit should Mavrick go with?
  • Total voters
    8
mavrick1903
Looking to replace 105k mile suspension componants on my 2007 v8 limited. Looking at Toytech. Wondering what the opinion of the collective hive mind is. I'd like to allow for adjustment if/when I add a bumper upgrade down the road. Want to lift some, nothing crazy. Want to make sure I can level left to right as well, dont want a "4th gen lean" as I've seen and heard about. I dont do serious rock climbing, I do two a load of 2000# a few times a year and don't want to sag in the rear when doing so. I live in WI, so winter is reason enough for me to add a little height. I'm considering the following:
Boss Suspension System for 03-09 4Runner, 07-09 FJ
FJ Cruiser/4Runner Ultimate 3" lift package
3" Lift W/ Bilstein 5100 Height Adj Coilovers FJ/4Runner
Or some other option? I'd like to avoid having to source parts from several sources. I'd like to "one stop shop" to save on shipping and complexity. The "Kit" approach appeals to me as it ought to get the job done in one order (or at least that's my thinking...)
Madison is a great place. I have participated in the Honor Ride there. Beautiful area.
I did option D, something else, but it would not beet your criteria. I have an OME kit. I really like the ride, I have not had issue with the 4th gen lean and the springs are stout enough to tow and haul. OME trim packers are $10 I think if you do have that issue. I have carried a few hundred pounds and came out level to a little rake, but I do have the shorter setup. The taller 895 springs would leave me with rake when loaded. The setup however is not adjustable as you requested so it doesn't sound like a viable solution. Whatever you get I do recommend rear lower shock guards. I have had mine out a few times and they finish didn't last. Will be refinishing and installing the guards before winter.
I did purchase through Toytec and found their service professional and prompt.
H.Sikina
