Which winch? 10k vs 12k
carlodonz
Member
Hi all,
I just received my C4 LoPro bumper so I'm shopping for a winch now.
I'm almost surely going with Warn EVO-S, it seems like a great option and fits the bumper well.
The EVO-S comes in 2 load rating, 10k and 12k lbs. I'm oriented to go with 10k but given the small price difference I might just "upgrade" to the 12k.
Do you see any reason why I should stick with the 10k instead? The weight seems the same, I believe the 12k pulls more thanks to different gearing.
Thanks!
If it were me I’d opt for the larger cap winch. More pulling power and less wear and tear on a larger unit IMO. I put a 16.5k on the Silverado and a 18k on the f450. Just make sure it’s not overly heavy for the vehicle your planning on permanently mounting in on...
-Chris
-Chris
trade that KLR 650 in for a DR650 and you will have a proper fleet of vehicles.:fencing:
Hi all,
Thanks!
You might want to check dimensions and compatibility with how large a winch your bumper can handle. Some bumpers, especially the lo-pro slim ones can't hold a 12k winch due to size. You'll likely need to move a coolant line and perhaps move the control box somewhere else.
I went with a Warn VR10S. Figure double the weight of the vehicle.
8k would've probably been just fine.
I read they get slower the heavier you go. Cant say if that is true as this is my 1st.
According to Warn's website, the dimensions of both are the exact same.
There are the only differences I could find:
GEAR REDUCTION RATIO
218:1 vs 234:1
MAX AMP DRAW/ LINE PULL
358 Amps / 10,000 pounds vs 396 Amps / 12,000 pounds
MAX LINE PULL/ LINE SPEED
10,000 pound/5.2 feet per minute vs 12,000 pounds / 4.0 feet per minute
