White exhaust after start
t3chfr33k
Greetings,
I have noticed over the past week that for a little bit after I start my runner, I get some white exhaust. It's never a huge cloud, but it is noticeable. I haven't been able to examine it too closely to determine if it is steam or smoke because it only occurs when I am accelerating. It can last a minute or two, but once the engine has warmed up it stops. It has been around freezing where I live, so I don't know if that has an effect on it.
I tried doing some research, but nothing I saw really described what I am seeing.
Any ideas? Thanks!!!
Greetings,
Sounds like normal condensation/steam/moisture which happens with a cold start.
I wouldn't worry.
If you are seriously concerned check your coolant level if it is low then it could be coolant but again i'm sure it's just condensation/steam/moisture.
I wouldn't worry.
Thank you. I know the coolant level is fine. I have checked that. I guess I should also add, it only happens after it has time to cool down.
Again, thank you!
Yup, steam comes out of the exhaust when it's cold out. Look at other cars driving by, they are probably doing the same thing. Mine puts out a lot of steam when it's really cold out. Completely normal.
averyberryman061493
