White Shadow Build Thread
cosmos7
Hello all!
Don't know if anyone will be interested, but after lurking around here for quite a while I figured I would do my own build thread to document my tinkering. Maybe it will be useful to someone...
Say hello to what my wife affectionately calls White Slut, or Shadow as I prefer.
She came into our family after our 2001 4Runner was brutally murdered when a careless college girl slammed into its side. After a few months of searching the perfect 4th Gen appeared just as my need for a vehicle was getting dire.
White Shadow is a 2006 4WD Sport, with leather, premium sound, heated seats that my wife adores, and rear tow bags. Her two previous owners were both in North Carolina before she came across the country to us.
Current modifications are mostly comfort items for extended drives and road trips. Listed here and which I will document in the coming days:
I have many, many desired changes for the future including lights, bumper, and a small lift. These are further out and entirely dependent upon budget. In the meanwhile I will likely continue to tinker around on the inside where mods are straightforward to perform and can be accomplished on a modest budget.
One of the first modifications I made was changing out the rear-view mirror. 4th Gens have a built-in temperature sensor, but I wanted a compass as well.
I found a screaming deal on a Gentex 453 mirror on eBay for $40 that included compass, Homelink, and auto-dimming. I followed 4RunnERD's installation instructions and it was a super easy install. The old mirror was locked to the adhesive mount with a single screw, and the new mirror slotted right on to that existing mount.
I've heard that some people have had trouble getting the overhead console down, but at least for me it proved to be super easy... just grab from the front and gently but firmly pull down. From there 4RunnERD's instructions made identifying the correct wires to tap easy. The mirror came with two covers for the wiring and I ended up breaking the longer one when I misjudged the size... they are kind of flimsy but look decent when installed and do stay in place properly. From there I just had to set the correct zone, drive to the nearest parking lot, and look like a complete fool driving in circles to properly calibrate the mirror.
After the mirror the next item on my list was to get my tablet up and running again. The tablet was an essential item for me, and provided both multimedia and navigation on road trips. I had used it in my 3rd for a number of years, although the previous installation used a long arm flexible mount that bolted to the passenger seat rail. It worked, but there was a fair amount of movement and my wife (and I'm sure other passengers) was less pleased about the device intruding into the passenger's area.
For this vehicle I was determined to do things a little bit better. After looking around the front of the vehicle I realized there was a fair amount of free space on the right side of the center control stack. I looked at a mount that attached to the stereo bolt points, but rejected it due to reported interference with the glove box. I ultimately settled upon RAM and its cornucopia of mounts and options. Taking the dash apart proved to be simple... start at the center console and start lifting pieces up and out, unscrew a few bolts under the dash and the surround comes right out!
I used a two-screw RAM ball as the base. I believe these are typically used at the device end, but I needed the room and the standard 1" ball mount was too big. I reinforced behind the ball with a steel plate to give the plastic some extra rigidity. The RAM tablet mount proved to be the perfect fit for my Samsung Tab S 8.4.
I also knew that the tablet would require power, and I also wanted to provide power for my wife or guests to charge their devices. There are a number of cheap options on Amazon, but I wanted quality and high-amp output so I chose a Bluesea Dual USB charger with a solid output rating. Mounting was a snap, although I did have to go to Home Depot to purchase a 1 1/8" hole bit to accomplish the task. I also had to mount the outlet a little off-center to avoid compromising the reinforcements along the outer side of the plastic surround. From there it was a simple matter to run pair of wires over to the inside fuse box, tap an unused location with an Add-a-Circuit, and tie the black wire to ground. I located both constant-on and ignition-on circuits, but opted for the constant-on to allow device charging while the vehicle is off. The BlueSea unit specs say it will only consume about 15mA in standby, so that's not likely to run down the battery very quickly.
I had initially planned a similar placement to my 3rd gen... down and to the right. I also wanted to make sure that the tablet did not interfere with operation of the stereo. This proved to be completely unnecessary as once I set the stereo to the AUX input I found I never needed to use the head unit itself... I never switched away from AUX, and volume control and mode changes could be easily made from the steering wheel. Thus I moved the tablet upward to a more central and useful location, with the arm essentially back up against the dash.
Having loose but necessary cables in the front cabin proved to be annoying, especially given the location of the AUX input at the bottom of the center console storage box. Additionally, with both auxiliary input AND power connected at the same time I was running into an interference issue playing audio on the head unit. Once again I took the console and dash control stack apart, and after adding a ground loop noise isolator rerouted the AUX input back to a short cable that comes out under the stereo and connects to the tablet. I procured right angle cables for both audio and USB power, and was lucky enough to find a double right-angled wound USB power cord to nicely clean up the installation, as shown above.
Once installed and in use I wanted to improve ease of operation. Playing my own music through the tablet and streaming if I wanted was great, but the steering wheel controls could only control the volume, and not the play/pause/skip functions. I found a tiny Bluetooth media remote on Amazon, but honestly while it did the job the little sleeve that clipped it to the steering wheel made it obnoxious and in the way. After thinking about this for a few days and wanting to just throw it out of the window I came up with a solution.
I took snipped the little wings off of the clip that housed the remote and ground the sleeve flat on the bottom. Similarly I pulled one of the button covers and also ground the top of it flat... if you want to try this be aware there is very little material on top and you can start to grind through the cover trying to get a flat surface. A little glue and I now had an easily accessible media controller! I also knew I planned to add lights in the future, and was able to find a Limited mid-console plate super cheap on eBay which gave me two extra future button locations and allowed me to move the seldom-used DAC control out of the way. The remote is intentionally mounted slightly off-center on the button cover to allow easy use of future controls placed next to it.
The tablet is now an essential part of the vehicle. Much of the time I use the display to run Torque and show extra gauges. Torque connects to the vehicle using a cheap Bluetooth ODBII adapter and can output all sorts of current information on the vehicle, including fuel consumption and both engine and transmission temps. The larger tires on the vehicle make the built-in speedo quite inaccurate, so running a GPS speed gauge helps make sure I don't inadvertently get a ticket. At some point I will buy the unit to adjust the real speedo, but for now this was a cheap fix and I wanted Torque anyway for the other information it provided.
In addition to the gauges the tablet provides a whole host of other functions. It's the international Tab S so it has both phone and text capabilities. It can provide navigation when needed, although I usually use my actual phone for that task. It also has enough horsepower to play movies and a few videogames in the downtimes on those long road trips. Thankfully it's also easy to remove and take with me...
I know I am writing to an ancient post - but need to express my appreciation. I printed this out and have mapped this course for my own 4Runner. Gracias my new friend
wwarren702
