who here uses TRS H11 hid kit?
tranmd
So I've been using the kit for over 2 years now. The H11 bulb in this kit has the return wire on top of the bulb when you screwed it to the housing. Anyone experiencing any shawdown on the ground because of this? Recently I've replaced the bulbs with TRS newer version of this bulb, which called H11xb35, which suppose to be better since the new design will eliminate the shadow since the return wire is now on the bottom when the bulb is screwed it. Now I have a new shadow. Shadow is more of a diagonal line on the left side. Anyone with similar issue?
My understanding is that the drop line you are experiencing is by design to reduce the intensity of light hitting the eyes of oncoming traffic. I found this in another post when I was searching for headlight aiming. I get the same line with my Morimoto HIDs and it moves as I work the aiming knob.
Check out the 2nd link in post 67 for an accurate picture.
http://www.toyota-4runner.org/5th-gen-t4rs/106978-hids-projector-headlights-5.html
Oh I'm not referring to the cut off line where there is a "step". This is a distinct shadow line on the ground on the driver side . annoying .
