Who to order redline MT90 gear oil
astar4runner
I got noise!! From Tranny/Clutch...
Posted and seems that I should start w/ gear oil change.
Gears are whining in every gear but 4th. One user said my syncros are shot in 1-2-3 and 5. Also I got 4th popping out of gear=shifter bushing and seat...right???
So I thought I would order redline MT90 gear oil, but from who? And order OEM shifter bushing and seat to fix popping.
One more?
I adjusted clutch push-rod so clutch would engage at about 6-7" from floor. Would this cause an issue?
Thanks for help
Sound like you need a transmission rebuild; I seriously doubt changing the lubricant is going to help much. MT90 is pretty spendy, about $9/qt, but trying it and putting in a new shifter seat bushing might buy you a bit more time. Check the Redline website for dealers near you.
Okay...
Yeah, it may buy me some time. I guess I should just take it in and cut my losses.
I did find tons of info on this subject. One write up said its just my " dried up at the point of the shifter fork and pivot ball stud" he said just to pull back shift fork boot from bell housing and grease area around ball stud and shift fork dimple.
I got under there but it's do hard to get anything in there and I cant see the area he's talking about.
Any thoughts out there???
