downpour11
Post up pic's of your runners with 9 wrap LC's!!
What is your coil set-up for the front??
yeah LINY I love it I've seen your thread....verrrry nice. Your 882's sit level with the 9 wraps? No top out spacer or nothin? .... you upgrading to 35's anytime soon?
Those running 9 wraps did you have to extend the rear center brake line? I just put 8.25 and 8.75 wraps from a Lexus and it looks like a would need to extend the brake line. But for now I just bent the tab facing perpendicular to the frame which gave me at least half an inch of slack.
if you run the 9 wraps with no added weight in the back and get the full 5+" of lift then yes you will need to extend the brake lines, but if you are gonna run a load in them you should be fine. but if you ask me with anything over a 2" lift ill be extending my brake lines just for peace of mind -their new and longer
I just picked up a set from THe kid.. Can't wait to get them on the rig. My 891's aren't cutting it anymore with all the weight I have in the rear.
But I am wondering how I am going to get these under the rig... Anything special you have to do in order to install these monster springs? Unbolt the panhard? Sway bar links? brake line?
