VoodooTitan
I did two searches to make sure a thread on emergency medicine or first aid wasn't already covered. I've created this in general discussion for the purpose of capturing the most attention, sort of like an all points bulletin.
After reading [MENTION=101600]hour[/MENTION] thread on being stuck in argentine pass in CO, I got to thinking... had he really been stuck out there for a few days, or worse, injured... what would he have done, and does he have the know how to help himself in a worst case scenario situation. I haven't read any horror stories on here about people being injured or in terrible scenarios, but I thought it would be beneficial to put the info out there, after all this is a forum.
Some background about me: I'm an Independent Duty Corpsman in the US Navy. My skillset is most comparable to a physician assistant. In a clinic environment, I see my own patients, order labs and special testing, perform full physical examinations and assessments, perform minor operations, prescribe medications, and recommend diagnoses. I also have an extensive background in emergency medicine. I've served 2 tours in Afghanistan providing austere medicine at the front line. My record is 20/21 (saves/loses). The lose was a local militant who was beyond saving due to blood lose.
With my personal and professional experience, I want to share some things I've learned, tricks of the trade, time savers, money savers, and things like that. I want to cover down on injuries, expedient/field treatment, and minor life saving procedures.
***DISCLAIMER***
I am not offering professional medical advice. I am suggesting things to consider when making your own first aid kit, and offering some guidance on basic life saving techniques you can use in worst case scenarios. Majority of this information can be found online, in official medical text, or survival books.
1. Injuries
These are some types of injuries that can potentially create a bad to worse scenario, drastically reducing your survivability. These can result from being outdoors or from your vehicle.
1. Burns
2. Electrical shock
3. Poisonings
4. Musculoskeletal injuries (breaks, fractures, disolcations)
5. Soft tissue damage
Soft tissue damage can result from a number of things. Penetrating trauma, crushing trauma, animal attacks, and movement on uneven terrain. Some of the serious concerns with soft tissue damage are infection and blood lose. I'll briefly discuss managing wounds later.
Burns can be classified as thermal, chemical, or electrical. All of these are real world when considering that we're dealing with various fluids from vehicles, high temperatures, and by products (such as battery acid). There are 4 stages to burns. Superficial, partial thickness, full thickness, and the 4th and uncommonly used is deep (typically reaching the bone). First degree burns are sunburns. Second degree burns are painful and typically result in blisters. Third degree burns are painless due to nerve damage, but are the most important to treat and most difficult to recover from. 3rd and 4th degree burns cause the body to have difficulty regulating temperature, resulting in hypothermia. This is a major concern when outdoors.
Poisoning can result from brushing against poisonous plants, coming in contact with poisonous insects, ingesting poisonous foliage, or overdosing on medication.
Musculoskeletal injuries are important because an injury of this nature can reduce your mobility and ability to protect yourself and get yourself into a better off situation. They are primarily due to trauma. Times to be careful are: when dismounting your vehicle on uneven terrain, using recovery tools such as winches or straps, moving on foot on uneven terrain, and traversing landscapes in search of help or to help someone. It is imperative you never place yourself between or underneath a vehicle that needs to be recovered without having something to support the weight in the even the vehicle becomes dislodged.
Soft tissue injuries. In long term scenarios these are the most life threatening. They can result in blood lose, infection, and potentially invite unwanted guests.
Electrical Shock. This is probably a one shot one kill type of scenario. Remember that electricity arcs, and there will always be an exit wound for the ground. If you survive an electrical shock, or are near someone who is shocked before doing anything else make sure you or the person are clear from the hazard. Lose cables, terminals, or wires are culprits. After doing this, check for the exit wound and dress the wound accordingly. I will discuss treatments later on.
This run down should provide some basic, routinely overlooked risks. Below i'll discuss treatment, and building a home-made first aid kit.
***DISCLAIMER***
1. Injuries
1. Burns
2. Electrical shock
3. Poisonings
