Will 285's fit on my Rig - Bilsteins 5100's 2.5/1.5
Status
Not open for further replies.
sullano4Runner
Hi Guys,
I'm a newb at this but have some questions. I have a Super White2016 T4R SR5 Premium 4x4 and just put on Bilsteins 5100's all around. Front set at highest setting (2.5) and a Rear DayStar 1.5 spacer.
Planning on getting the SCS SR8 rims (17-8.5) and (-10mm offset). Will 285 BFG KO2's fit without having to cut or mod anything else? Or should I get 275's so I don't have to worry about it??
Any advice please???
http://www.toyota-4runner.org/5th-g...ner-owner-need-help-searching-start-here.html
http://www.toyota-4runner.org/5th-gen-t4rs/92594-modifications-write-ups-quick-links-faqs.html
Either of the above stickies would lead you to these threads:
http://www.toyota-4runner.org/5th-gen-t4rs/208403-changing-tire-size-wheels-read-first.html
http://www.toyota-4runner.org/5th-gen-t4rs/156378-going-bigger-5th-gen-tire-fitment-guide.html
Short answer: you will probably rub on plastic, probably not rub on anything metal. You may have to shift the fender liner forward (see fender liner mod at above links) and/or cut or remould (with heat gun) some of the black fender plastic and/or mud flaps.
Right answer.
OP read the links helpfully posted above.
Thread closed.
-mod-
Status
