Will 295/70-R17 Nitto Terra Grapplers clear with 2inch front lift?
BOFFROAD
I found a set of Rims with 295/70-R17 Nittos Terra Grapplers mounted on them for sale. Will they fit on my 2003 4Runner without rubbing. Its a 4WD V6 with a 2 inch lift on the front.
ill you know right now with the Toytec 3in boss kit i clear my 285/70/17 with a 1.25 spacer but still rub when trying to full lock to one side.
Ya 285/70/17 still rub in full lock for me as well. Other than that though they are great. Anything above that and I would assume you would have some issues that wouldn't be worth that extra size over the 285's.
Have either of you done the body mount chop? Just curious.
No. I had 285/70/17 on my Runner with 1.5" spacers and still rubbed with my 2.5" Daystar lift. Trim the body mount, pull the liner forward, then slight trim on the fender as needed and you'll be good though. It's pretty simple.
I'm lifted nearly 6 inches in the front with the combo of 5100s and lift spindles. My 285/70s still rub... Then again, I need to take the time to push my liners forward and stuff
