Will fog lights from a Limited bumper fit in an SR5 bumper?
piperoo
I have an SR5 with the blanks in the bumper...so it has never had fog lights. Thinking about some fog lights that came out of a Limited bumper. What are my options?
Wiring harness is already on your truck. If you get the dealer part it should just be plug and play.
Even if my 4Runner didn't come with factory fog lights? Where would that harness run to in order to hook to the fog light switch that also didn't come with my 4Runner.
As far as the harness for where the lights plug in on the bumper yes its there. I imagine the harness for the switch which you will have to buy is there also. If not sure it won't be to difficult to get it setup. Just go look under you bumper and you'll see the plugs.
I just realized those lights being on is determined on the mode of the headlights with all the factory wiring. So not sure if there will be a switch but I know you can wire it up that way if you chose to.
So I got under there...there aren't any wires going to the 'blank' holes for the fogs, BUT there is a wire and connector that is coming off the back of the rectangle lights that are in my bumper....is that what you are talking about? That would plug into the fog lights?
Then I would just need to find where that is actually running to.
Yes, I looked under mine also and I believe those plugs that are hanging off of the parking lights are for the fog lights. I'm almost 100% positive. Let me know how the install goes. I'm looking to install fogs on my SR5 soon also.
Will do. I am trying to figure out how to install a switch and to where those wires hanging off the DRLs go....will have to connect those to the switch somehow...once I figure out where they go.
I would also like to find out about the wire's under the dash and how to install the foglight's. I was wondering if anyone has a nice write up on the installing of the turn signal stalk & how hard is this to do on my 02 runner??? Thank's for any help....Run on..
