Will not Crank
willisr
I have a 1988 Toyota 4Runner with 3.0 V6, I have replaced the fuel pump and still will not crank, i have great pressure at the fuel rail. If i pour gas into the throttle body it will crank and run fine till it burns what gas i poured in it. Can someone give me some ideas.
Thanks Ray
Did you actually pull out an injector and make sure it's spraying?
If not try the cold start injector.
