will these wheels fit? Eagle 102 17x9
DanDLT
subjet: 2005 4runner sport edition Stock suspension street suv
http://www.aewheel.com/eagle_alloy_wheels.cfm?id=101#
these are the look i want
17x9 Polished 6 on 5.5 Acorn -8 mm offsett 4 5/8 Backspacing
they also show a size
1029-8994 17x9 Polished 6 on 135mm Acorn -8 mmoffset 4 5/8 backspacing
they also have a Series 102
same style but a center cap where you dont see the lugs.. will these fit?
i also like these series 195
http://www.aewheel.com/eagle_alloy_wheels.cfm?id=257
they come in 17x10 or 17x8
17x10 Polished 6 on 5.5 Acorn -24 mmoffset 4 1/2backspacing
will the 10s be too wide? stick with 17x9 or do even need to go smaller 17x8?
im planning on getting some
275/60/17 proxes or yokahamas tire on one of these wheels
will this size tire fit on one of these wheels ? and work on my 05 sport edition 4runner.?
ill use my existing revo set 265/65/17s until i can save up for the 275/60s
how bout these
http://www.aewheel.com/eagle_alloy_wheels.cfm?id=356
or these
http://www.aewheel.com/eagle_alloy_wheels.cfm?id=104
there is a set on ebay
item 260052352394
here are the Procomps same look will these fit?
http://www.procomptires.com/pxa1059.html
17x9 6x5.5 -8mm offset 4.625" backspacing.
has anyone tried these types of wheels?
will these offset or backspacing leave the wheel tucked in or stick out a bit.
im running 1.25 spidertraxx already, will i need them with these wheels ? or take them off? i can go either, i like how the spidertraxx make the stock stick out a bit..
any advice is appreciated.
heres a pic just for fun.
Consider stock is 7.5 with +30 offset equals 4.93" backspace any of the wheels will fit. I'm not a fan of excessive negative offset, so I'd avoid the -24mm wheels.
As for tires, 275/60/17 is slightly has a slightly smaller diameter than stock 265/65/17. You may want to look at 275/60/18.
Good luck.
Thanks for Replying Rook,
so do ya think i will need the spidertraxx adapters if i go with
17x9 wheel with
-8 mm offset and 4 5/8 backspacing?
and tires 275/60/17
ive read others have got them but not sure if they do hit the caliper, will it hit on the inside of the rim on the edge of the caliper or on the side by the lugs?
wasnt able to clarify but.
if it touches the caliper on the side, the spidertraxx would fix that.
but if the inside of the wheel rim touches the caliper i can grind it down a little, ..
so with a -8 offsett gives a deep dish look right?
how far will they stick out from stock ?
then if i need the spidertraxx they may stick out too far
what would be ideal?
i would think if i can get em on and grind the caliper and not have to use spacers would be best. i still want them to stick out a little like they do now with the spacers. i could always find a smaller spacer..
do i have to worry that they tire may rub on the control arms or anything with these and tires?
or do i only have to worry bout them hitting the caliper..
the 275/60 is not a very big tire .. just a little wider..
do ya think i could get away with a
285/60/17? there is a toyo proxes this size
or there is a 285/70/17??
thanks again.
goddesszilla
