will this cheapo antenna work?
Jc12
Hey so as with every other t4r.. eventually. the teeth on my antenna bit it and it just stays stuck up while the motors pumps. Can i just attach this antenna and huck the stock chrome telescoping one?? This one only measures 13" and is $9 (reception?.. i have stock headunit for the next month or so). can i just unscrew and pop off the old one and screw this bad boy in? thanks!
* i know the motor will still go but i will be disconnecting it in the near neaaaar future.
At the time being i dont want to do the taco whip mod so i am looking for an alternative :reddance:
Antenna
that antenna if i'm not mistaken screws into a base. unless you get the base to go with it, i don't think its going to work the way you think it will.
The point of the taco whip mod is to change from a telescoping antenna base to one with a screw-in antenna base.
So no, the only way to get a different antenna is the taco whip mod.
Theres always another way to do things....
The little stubby guy beside my Firestik is my am/fm antenna. Works just as well as the original. I couldn't justify spending 60 something $ on an antenna since I rarely listen to the radio anyways.
