Will this fit?
Same year but the frame mounting points are a little different.
So let me explain how they are not the same. ( but you can easily make them the same).
Our 4runners have a large thin plate of steel butt welded to the front of the frame to which our factory bumpers attach to.
The tacomas frame have a smaller plate welded to the inside of the frame with a nut on the inside making it a mounting point.
In the picture you can see one silver bolt head running into the frame where this mounting point it at.
This is a common conversion because when adding a aftermarket bumper and cutting off our large butt plates and welding in a smaller threaded end cap it provides more support for winching off the bumper.
2001ATL
