I could not find any information..
I would like to know if this set-up would work O.K
2011 TE(In driveway)
4x Bilstein 5100(ordered)
2'' All-Pro rear springs(in shopping cart)
would like to run front shocks set to 2.5'' up front and the All-Pro springs out back.
Running 2.5" up front on the Billies, might, might require some aftermarket UCA's to get your alignment dialed in...
As far as the back springs, stay stock, save money and add a spacer.
*Disclaimer*
I'm not a real doctor, but I play one on the interweb...
Will the rear springs work if I run the common 1.75'' setting?
or would the ass end sit too high.
Check this: LINK
My 2010 TE started with about a 2" rake. I raised the front to the full Bilstein height of 2.5" and added rear 1.5 Daystar spacer, which only added 1" due to the weight on the rubber spacer. I now have about a .5" rake.
this would work just fine, a couple guys on here have that same setup.
Not to argue, and it is probably the angle of the camera, but it looks more like a .5 reverse rake to me! Nonetheless, very nice looking rig!
