Winch mount offerings
raycie
Thinking about getting a winch especially for the very rare time that me and the family would go out to camp by ourselves. With that said, the campground we go to is fairly popular and is also policed by a department of land and natural resources (every so often). So far, we always go with a group, so until now, it was never an issue. I had a plate bumper on my old tacoma, no winch, but not in the mood to get one for the 4R. I do also have a hilift extreme that I could use as a winch if really needed one... Did even start looking a front hitch mounts for a hitch winch, but the ones Ive seen look like you would loose a bunch of ground clearance..
Searched, and see possible offerings from undercover, budbuild, southern style, and Pelfreybuilt... I do like that some have integrated shackle mounts while other don't.
Any input on style, strength, or even bonuses (like shackle mounts???
Thanks..
Thanks..
My 2 cents - based on the use you described, I wouldn't even bother with a winch. The hi-lift is the perfect tool for self-rescue in emergency situations, especially since it sounds like the area you plan on going to is pretty low risk. Easy to just toss the jack in the truck when you're heading out and pull it off when you don't need it.
I would not bother.. Adding a winch adds many safety concerns in a collision. Unless you are an extreme off-road enthusiast and want a plate bumper + suspension to support it.. it's generally a bad idea.
Best bet is manual recovery gear. Max trax are great. A good manual winch like the WS More power puller will pretty much get you out of anything. However, If you are getting stuck all the time... running in mud or creeks alone...there is no replacement for the utility of powered winch. I just would never bother without doing a full bumper, since you are getting all the weight and other negatives.. might as well get the clearance and durability to go with it.
I really like having a winch. It's just so dang handy for all sorts of stuff in addition to vehicle self recovery.
One pretty easy way to add one would be a front receiver hitch and a hitch mount winch. If you want to get in as cheap as possible, the hf Badlands winch is pretty good - and if you play your cards right you can pick up a 9k lbs version for just over $200. Add another $50ish for the hitch mount, and $150 for a front receiver, plus $50 for some good quality 4guage jumper cables, and another $20 for some Anderson connectors and you can make it really easy to use. Use the gray 350amp connectors.
Drop an anderson connector plug hard wired to the battery under the front bumper. I have one on my 4runner because it's awesome, even with a hardwired winch. Want to jump a car - just plug in the cables, no need to open the hood.
That makes it the easiest to install and remove when you don't want it. And you can put it in the rear hitch and use the jumper cables to power it if necessary.
I used this setup for a long time in a 3rd gen. Worked really well. Still have it.
I did a permanent mount on a plate like a UHWM in my 5th gen because the front hitch sits pretty low. It depends on how often you'll use it. I built my own winch mount because I can built it for free. Otherwise the available options are pretty reasonable on cost compared to what a custom shop would charge. They're easy to install if you're pretty familiar with this type of thing. Expect to end up about $1200 into it for the plate, winch, and extra wiring and such to make it work nicely (assuming $500ish winch). I have a superwinch with synthetic and it's been flawless so far. Then again other than breaking the cable a few times so was my $250 harbor freight winch. The only winch I've repeatedly broken is my Warn 8274.
One other consideration is that it does put a big more weight up there. You may find you'll want some small spacers up front to compensate.
It would be easy for any welding shop to add shackle mounts to any of the plates The only tricky part is going to be cutting up your bumper to make 'em look pretty. Because you basically have a bit flat plate behind the bumper, I would drill it before installation. Then use a piece of something like 3/4" flat bar that would bolt into place protruding through the bumper cover.
Something like this should work nicely - although ideally you'd want more like 10" long due to the spacing and having a bit of extra material for longer welds or bolt them on. As an added benefit if you lay this style flat they'll be in the proper orientation - 90* to 99% of them that are set up vertically when they really should be horizontally oriented. Personally I would just use the factory tow loops. But this is an easy option to add.
Good luck with whatever you end up with!
Wow.... just spent a while researching and reading about the more power puller... at 26lbs, that may be a good route to go. I do have the hi-lift, but needing to carry around 30'+ of chain could be a pain, and heavy. I like that the power puller has a industrial following and that it has 35' of synthetic.. add to that a recovery strap, and your in business...
Those can work well. The only real issue u see is that there are times when even 80 feet of line isn't enough to reach the anchor point. The 8274 is popular in part because it has 150 foot spool capacity. Won't work on 5 th gen though. The other consideration is that you can't pull while you drive. Sometimes you might want to do both. Other than those downsides a big comealong can work really well. Might fit your needs well.
After looking at the price of the more power puller - i wouldn't buy one. It's WAY too expensive for what it offers. The "3 ton" version relies on a pulley, so it's roughly equal to a 3,000lbs single line pull winch. And the 35 feet of line means you get about 15 feet of usable pull distance. Is that enough? Probably, but don't be confused.
Mostly my issue is that it costs $300+. For that amount of $ go buy one of these Amazon.com: Powerbuilt® 4 Ton Cable Puller Come-Along with Double Gear - 642245: Home Improvement for $35. Spend another $30 on a 40' long length of raw 1/4" dyneema rope and make your own synthetic rope for it. Then buy another 100 foot or so length of 5/16 dyneema rope and cut it into one 30 and one 60 foot length and make your own ends (it's super easy - even for an idiot like me. I make my sailboat rigging from synthetic rope.) Use the rest to make a few soft shackles. And you're in business with an equivalent pulling power, plus a couple nice long extension ropes to get to an anchor point. Should be able to put it all together for about $100. Spend the other $200 on a set of max tracks?
I may be biased, but I do like the hybrid winch style bumper we offer. We actually have quite a lot of material in stock to get whatever options you want made up in under a week. Also have a silver powder coat one ready to ship that has a scuff on the very bottom of it 20% off. Its got the 25" flush mount led,hoop, shackle mounts. I'll let it go for $975 shipped. Let me know!
Love that bumper with the hoop!
Second on Jetboy's suggestion. If it's really just a once in a blue moon necessity maybe don't even add a front receiver and just use the rear to pull yourself back out of whatever you've gotten into.
I love my SlimlineSS but adding it, or any winch/mount is probably going to necessitate front end mods.
- Jeff
- Jeff
Oh don't worry.. Front end mods are coming no matter what... lol
Jhunt
