You might also consider the weight of your wheelings buddies.
most winch companies recommend 1.5 x's your vehicles GVW
Yes, this is Warn's recommendation. So a question: do you factor in additional weight for mods ? they can add up..... Anybody install a Warn 10,000 lb in a C4 Fab Low-Pro ? Wondering if there are fitment issues
Yes. You absolutely factor in the curb weight with mods. I run a 10k winch and I think my vehicle is sitting at about 6200 fully loaded.
Thanks for the reply. Interestingly though, when speaking to Warn customer service, they said that the 10,000 is plenty winch for our Runners (if you do the math 6,300 GVWR (2014 4x4) times 1.5 = 9,450). Not much room for Mods.
keep your vehicle under GVWR
I've bolted 350 lbs of steel onto mine and got it weighed on a truck scale the other day with a full tank of gas. 5060 lbs exactly. I weigh 190 so that's 5250 lbs. I have an Engo 9000 Synthetic. It'll have to do. I do plan on picking up a couple of snatch pulleys too though. BTW I had to relocate the solenoid pack into the engine bay to make it fit.
RCI Rock Sliders ......................110 lbs
RCI Aluminum Integration Skid 10 lbs
RCI Transmission Skid ............. 30 lbs
RCI Transfer Case Skid ............ 30 lbs
C4 Fabrication Fuel Tank Skid . 65 lbs
Pelfrey Hidden Winch Mount ... 45 lbs
Engo 9000 S Winch .................. 55 lbs
Total Weight Mods .................. 345 lbs
