windjammer tonneau cover?
I've never seen it, but I agree it'd be pretty cool. Maybe make your own if you're good with the needle and thread? Probably not... Just Rhino Line everything in the back and go topless. Things are always better topless
Did you remove or replace the rear interior panels with some thing rhino-linable (something other than the stock carpet vinyl panels)?
I removed all the cloth and vinyl from the panels and traced them out onto some wood panels. I marked out all my holes and then sprayed them with the spray on bedliner from wal-mart. It looks ok but there is nothing like the real rhino liner, or line-x. I did have the very rear panels done with the rhino and they turned out pretty good. I wanted to put 6x9 speakers backe there and the plastic panels seemed a bit flimsy so I had them lined. The only thing i did not do was have the uv protectant applied on any of the rhino liner. I must say i should have done it. I will from now on.
I have since taken out those panels and have made some 1 piece lexan panels for each side and the tailgate. they will bolt up in the factory holes and have two marine grade 6x9's on each side.
