Windows icing on the interior
-JD-
As the title says my windows started to ice up on the inside on my drive to work this morning. It was very cold, as it is most places right now.
Is this normal?
Or is this a sign of moisture getting inside the vehicle somewhere?
The rear drivers side was the worst but was also forming on the cargo area windows and the back half of the drivers window. I think the defrost blowing on the glass was the only thing stopping the drivers window from icing up fully.
I would say moisture, or humidity, inside the vehicle. Could be something as simple as the snow you are tracking in on your boots that is left sitting on your floor mats.
Basically, there is warm air trapped on the inside of the vehicle. Cracking a window slightly overnight should resolve this.
News - How to prevent frost from forming on the INSIDE of your car - The Weather Network
Why do the inside of my car windows get frosted at night? - The Globe and Mail
This was my thinking as well... it doesn’t take a whole lot of moisture inside that sealed environment to condense when it’s cold enough outside, and then freeze on that surface.
recirc on
if you have the recirc. air on even for a few min. and its cold or wind hitting the one side more than the ocher it will ice up on that side quicker, it was -47 degrees celsius yesterday:jaw:
I can't really find any source of moisture other than my own breath. Still iced up badly this morning with the AC running to dehumidify.
Try damprid.
Used it back in the day while in college and broke ass. Leaky sunroof was killing me. Kept that thing in the car and it worked wonders.
normal condition if you have a wet floor.. air temps below 30F and wet flooring .. many have had windshield leak or hvac box leaking into the interior.
ac does not turn on compressor 30F and lower unless the engine is at operating temp when not moving . compressor will not operate much when this cold out so not gonna help.
check the heat on full
Make sure the dial is all the way every mm to the hot, it effects output, on a side note warmed up to -30 degrees c today.
