Windows XP OS question.
Net4n6
Can I install Windows XP (with all correct drivers) on tablet laptop and get all the tablet functions to work?
Do I have to install tablet version of XP on tablet laptop?
I have been working with layer 2 and 3 for so long :nerd:. I've not work with layer 4and up for a long time.
My sister's tablet crashed but she lost the recovery cd.
Yes, you can as long as it meets the requirements. 300mhz CPU, 125mb of RAM(memory), 1.5 Gb of available HD space, and SVGA(800x600) video adapter.
So I think all 5 yr old laptop can run Windows XP. Tablet Edition XP is a shrink version, it means unwanted applications are removed. Having a computer that comes with a Tablet Edition OS doesn't mean its not upgradeable to Full Edition or maybe to a newer version of windows as long as it meets the minimum system requirements and like you said, you have the drivers for it. Important drivers are : Video driver, Sound driver, LAN and Wireless Network Adapter. If you don't have specified drivers, just wait for it to appear in the available updates for download and the "Service Pack". 99 chances that it will download including the drivers lacking.
By installing a recovery CD from a same model may have problems as it might detect the ID of the Bios and original hardwares that its not the same computer registered to MS... Some will install using same serial # because MS said a serial # can be used in 2 computers. But I don't know w/ recovery cd's, because the CD itself is an image to the HD of the computer where it was originally installed.
Easiest is to have an OEM version of XP.
Don't mind if the laptop has corrupt OS, Just turn it ON, Insert the Windows XP, boot from CD, when setup detects a previous XP installation in its corrupt hard disk, select format the drive option, then setup should continue.
:cheers:
Borg,
Great. Thank you for the info. I installed non-Tablet version of XP on her tablet. I couldn't get the tablet function to work. I checked device manager and no "error"/red or yellow icon.
Per your tread, I need to install more drivers for the tablet function to work properly.
Borg,
Sorry, my answer is just to support the installation of XP in capable computer.
I am not well verse in Tablet PC's, if you mean the TIP - Tablet PC Input Panel, I think You can download that, and there are tablet pc softwares also available for download. You need to do it one by one.
Tablet PC Input Panel For Xp Pro, Home, MCE and Original Windows 7 Mat - WinMatrix
Maybe we need to read more.. ha! HA!
Here is the download page of the TIP( If this is what you mean):
Download details: Update for Microsoft Windows XP Tablet PC Edition Development Kit 1.7
Install it and see if you can use pen
Edit: http://www.microsoft.com/downloads/...FamilyID=b46d4b83-a821-40bc-aa85-c9ee3d6e9699
Great. I will try to intstall them tonight. Thanks. You're a life saver.
I installed all the drivers. Everthing worked fine except the touch screen. Darn. Anyone has any idea? I spent 3 hrs googled but no luck to fix it.
