Winter Prep.
I was just looking at them yesterday! I like the magnetic ones because I can just throw them on when I go skiing or someplace really cold instead of getting a Wolf that sticks on. I was doing some research over on the oil forum and there is a ton of threads, none of which were conclusive for block VS oil pan heaters. If you want to read through them you can go to Google advanced search and under site put in bobistheoilguy.com and for search terms put in oil heater, or engine heater, etc. I was surfing through them for about 2 hrs lastnight! Bottom line is they work if used correctly(dont turn them on 30 mins before hand after the car has been sitting out all night), but using a synthetic oil is one way to reduce the need for one.
HTH
Hey thanks for the info direction.
I have changed to synth, and i also have a magnetic kats pan heater. Not really impressed with it. didnt put off any heat, to cold in winter for it to make a big difference i think.. 200 w or 400w for the big one.
looking at the tank heater because it circulates coolant through the block and keeps thing really warm.
gets cold in fargo i hear...
heh
Then either a tank, block or inline heater unit would be your best bet. On BITOG they get pretty deep into it, like thermal dynamics and stuff, good info.
