Wired carburetor
Rebelson
I just got this 87 4Runner and this was a original fuel injector the guy I got this from took it out and I was ok with well I got it here during the day and the carb would not ide at all the temp was in upper 80s well now it is 58.6 °F
the carb ide fine right now can you pleases give me some info thanks
Is it a factory AISIN Toyota carb? If so....it could be a lot of things. I would start with the choke. I do not know much about the AISIN carb as the first time my pickup had a problem with it I just yanked it and dropped in a Weber 32/36 and have been living the good life since.
I will get a pic of because I do not know if it is well I fix a vacuum leak it want's to idle when you start and will idle until you go up to 3 rmp and let off the gas the thing die most of the time did not today
Well here is the carb also a replacement carb I got with the truck you tell what there are
This one is the one that is in the truck
cccccc003.jpg~original
cccccc004.jpg~original
cccccc002.jpg~original
This is the replacement the only reason I have not try it yet is because the last owner said it needs to rebuild and plus I do not know if it will fit
cccccc009.jpg~original
It has been a long, long time since I have seen a stock 22R carb, one thing I can say for sure is it is not a Weber or any type of Holley that I have come across.
The only thing that I can come up with for what you have is to double and triple check all of the vacuum lines. The stock carb may have an idle solenoid that is acting up in warm weather, but again, I do not know enough about the stock carb to be sure of anything.
Luceann
