Wiring color code
wieyu
Does anyone know what are the color means for each wire? Like what color is negative, positive, ground, etc. ? Thanks
It's not particularly consistent throughout the vehicle. You'll need a wiring diagram for the function in question.
Which year is your truck, and what are you trying to fix/change?
I'm also looking for a wiring diagram of my 2006 SR5 4WD T4R. Anybody can share this info?
Thanks.
wiring colo code
I'm trying to find out what color is negative and positive wire on my parking lights. I see red, black, black with white dashes.
I'm trying to install an after-market projector headlight and connect the wirings to my existing parking light wires.
Thanks for the replies guys.
I have a 2004 4Runner Limited
I got the 2007 Repair manual in zip format. If I can't post it here, just email me. I'll get it out to you. Put 2007T4R in subject matter. Actually, I just attached it to this post, if that works. here goes. luck
You guys will agree, this is a wealth of infomation. I opened a few sections, and I do not see actual color codes. They do give outputs/voltages for the connectors. If you are good with a multimeter, you are set. It is a 202MB file, that this forum will not let me attach. It is marked '2006 T Repair Manual'. hope it helps.
Thank you very much everyone for your replies. It will help me a lot. By the way RAN, if it's possible could you please send the manual for 2007 4Runner you mentioned before to my e-mail address? Thanks.
Hey guys, a lot of us did not put email addresses in our member info. I have sent out a few private messages regarding this file. PM me with an address and I will get this out to you. I got this off of one of the other forums. good luck all.
Here are the abbreviations and explanation for their wiring diagrams.
Apologize for the large JPG, otherwise it would be unreadable.
Also, here is link to download the PDF file for the wiring your diagrams looking for (from the Repair Manual)
Download Link: Wiring Diagrams for 2007 4Runner
DeNz said:
Cool..
Is this similar to 2006 model?
I'm not positive, but it seems the 2007 repair manual covers mostly all the 4th generation 4Runners, because there have been very few changes across the 4th gen line over the last 4 years, which have been mostly cosmetic.
The Manual I have also has the Urban Runner changes/updates which are very few differences and only adds a few PDF's to cover these changes.
Thanks....
allcarhistory
