dudeguesswhat
So i've got an 87 4runner SR5 that I decided to clean up the wiring on. The previous owner ran a seperate ACC and power wire. (as opposed to using the stock harness ones) The power wire was run to the fusebox by the battery and spliced into the horn fuse, so I yanked it and wired my radio back into the stock harness. Now she turns over, but won't fire. My check engine light doesn't illuminate either, but my oil temp and emer. brake light do when key is in the ON position. Every fuse in my fusebox is good, ist here something I'm missing? Any help would be appreciated, thanks!
