lmturne1
So here's my predicament, I've purchased an OPT7 lightbar and have successfully installed everything (harness runs from the plug on the back side of the light bar down the inside channel of the A-Pillar into the engine bay, the relay and inline fuse are wired and the included switch has been run through the firewall) but my problem lies in replacing the original 3 prong toggle with a push button factory replacement from Air On Board.
The air on board switch has 4 wires (hot, switch, ground, ?) my objective here is to obviously have control over the light and dim the LED's on the switch using the dimmer function in the vehicle. I've look up some other tutorials and have had no such luck when trying to tap into the grey wire (signal) from the dimmer switch.
My problems are this, I have power to the switch and the LED's light up, but 1) no power or signal to the light bar and 2) no ability to dim the LED's on the switch.
My previous wiring experience entails screwing in light bulbs and I'm still 50/50 with those...
Someone please help.
